what kind of ckt does this?
Discussion in 'General Electronics Chat' started by raffter, Sep 2, 2008.
  1. raffter
    Thread Starter Active Member
    Feb 28, 2008
    113
    Hello all,
    I was wondering WHAT kind of analog circuit does this function...
    for every positive pulse input, the output, raised(to 1V) will pulse to 5V then "dip" for a moment to 0V then back to 1V again.... the 1V can be done with voltage reference(im going to use op-amp)
    I have been thinking about HOW I would go about doing this, but seems cant figure it out...yet
    tia :)
    Ralph
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Did you intend for the negative-going pulse to be aligned with the trailing edge of the input pulse? If so, you may be able to get away with a RC differentiator circuit.
    hgmjr
  3. raffter
    Feb 28, 2008
    113
    ^nop... its not "timing" critical.... just a few Hz(1-10)... ok i will consider that :) thanks!!
