What kind of circuit is this???
Discussion in 'General Electronics Chat' started by Nubsparky, Nov 27, 2015.
  1. Nubsparky
    Nov 27, 2015
    11
    [​IMG] Can someone please tell me what kind of circuit this is supposed to be given the components in the diargram???
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Maybe if we could see the diagram?
  3. Nubsparky
    Nov 27, 2015
    11
    Mike, I'm sorry. I've been trying to get the picture uploaded...having some trouble. Thanks....
  4. #12
    Nov 30, 2010
    16,690
    7,330
    Website blocks noob pix. I will tell Mod to check.
  5. Nubsparky
    Nov 27, 2015
    11
    Ok...finally got it up...I need to know what it is and what it might be used for...I'm guessing it some sort of pushbutton controller circuit with an alarm of some sort???
  6. #12
    Nov 30, 2010
    16,690
    7,330
    PB one is "alarm latch on". PB2 is "stop alarm" or, "manual reset".
  7. Nubsparky
    Nov 27, 2015
    11
    Thanks for your help!!!!!
  8. Nubsparky
    Nov 27, 2015
    11
    PB one is "alarm latch on". PB2 is "stop alarm" or, "manual reset".[/QUOTE]
    I have one more question....its a bit of a word problem..."What is the electrical consumption in KVA of the motor powered by a 3 phase 460V supply and drawing 17A constantly????
  9. #12
    Nov 30, 2010
    16,690
    7,330
    There are no 3 phase motors in your schematic. Please start a new Thread or all you will get is people that do light bulbs and buzzers.
  10. ISB123
    May 21, 2014
    1,240
    531
    8100 W
    13500 KVA
  11. ScottWang
    Aug 23, 2012
    4,930
    777
    The files size that you attached were too too big, I was compressed them to the normal size, they are from about 8MB compressed to about 37KB, next time before you upload the files, please compress the photos to 800x600 or 640x480, if necessary then you can compress to 1024x768, almost the photos using 800x600 image is enough.
    Too much file size will affecting the connecting speed of members to get into the forums, thanks for your understanding and cooperation.
  12. Nubsparky
    Nov 27, 2015
    11
    Thank You!!!!!!!
  13. Nubsparky
    Nov 27, 2015
    11
    I'll be more mindful of that the next time I post pics. Thanks.
  14. ScottWang
    Aug 23, 2012
    4,930
    777
    And please don't using the wrong file format, jpg is for normal photos, png is for simple horizontal and vertical line and less colors, gif is between both.
  15. BR-549
    Sep 22, 2013
    2,181
    419
    The brown paper circuit use to be commonly referred to as a 3 wire start/stop circuit.
    X is the winding of the motor start relay. X1 and X2 are latching contacts on that relay.
    PB1 is the stop button. PB2 is the start button.
    X1 latches the relay. X2 is auxiliary accessory latch.
    L is a lamp indicating control power.
    Most simple 3 phase motor control circuits I have seen have the control transformer between 2 line legs.
    Most control voltage was 24 and 120 VAC. But there are other methods and voltages.
    They use to rate motors in HP. At 480 3 phase, each HP will take about 1.1 amp.
    At least that’s what wives tell.
