what is your thoughts on this?
Discussion in 'Embedded Systems and Microcontrollers' started by Roen Hayden, Dec 6, 2007.
  1. Roen Hayden
    Sep 10, 2007
    22
  2. eeboy
    Sep 27, 2007
    90
    Should be a good start...
    Yep, a USB-Serial converter works just as if you had a serial port. No issues there.
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    It seems like a good kit. The comments rate it high. The chip is not removable so you can't use it as a programmer for other chips. I can't find out who made it so don't know if the usb/serial device is Linux compatible but if you're using it on windows that won't matter.
    I'm using the arduino and the FTDI chip shows up as a virtual com port. It works the same in windows and anything that will talk to com ports like processing, flash, max etc will work with it.
    Once you get the tutorials done you can learn how to make this
    http://www.processing.org/ talk to to that kit. The kit can gather data and send it to processing, processing can then talk to the device and tell it what to do. I'm told flash and max will do it but have no idea about them.
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    It looks to be a good kit with which to explore the fun of playing with robots. The serial-to-usb should not be a problem. The comms link is just being used to download you own software control routines as far as I can tell.
    The kit will no doubt provide many hours of enjoyment.
    Once you have assemblied it and become familiar with programming it, please come back to the forum and give us your impressions of the pros and cons of the kit. I am sure there are other members who would be interested in obtaining the kit for themselves.
    hgmjr
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    I concur with the above, a very reasonable price for what must be a good starter kit for getting into m/c and programming.
    Let us know how it goes.
    Dave
  6. Roen Hayden
    Sep 10, 2007
    22
    Ok I sure will let yall know the pros and cons of it.
  7. Roen Hayden
    Sep 10, 2007
    22
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
