What is wrong with this charge pump circuit ?
Discussion in 'General Electronics Chat' started by IcedFruits, Nov 17, 2014.
  1. IcedFruits
    Jan 15, 2014
    84
    hi, i was trying to simulate charge pump with 555 in ltspice, the first one with direct 555 o/p to pump capacitor works just fine as it should, but the 2nd one with added npn transistor (for bigger current handling purposes) fails to do the job.
    checked, while not connected to pump capacitor C1, clocks are at same phase at both 555 o/p & Q1 emitter. but whenever C1 is connected, emitter clock disappears & steady ~4.5v appears, also charge pump fails, with only ~5v around C4.
    i have included both ltspice files (working & not working) in the attached zip file. please run the simulation if needed and kindly help. really confused.....
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    For starters, R5 is too big by about three orders of magnitude.
  3. IcedFruits
    Jan 15, 2014
    84
    checked with 20k or 1k values @ R5, they did not work.
  4. blocco a spirale
    Jun 18, 2008
    1,459
    369
    I don't see how the output can sink enough current to charge C1; I think you should replace Q1 with a push-pull driver stage.
    Take a look at the schematic for the 555 and you'll see why driving the charge pump directly from the 555 output works.
    IcedFruits likes this.
  5. IcedFruits
    Jan 15, 2014
    84
    amazing, sir ! u're a genious ! that worked ! i think i can tune the rest now, still suggestions are very much appreciated. :)
  6. cmartinez
    Jan 17, 2007
    3,698
    2,764
    After looking at your post, I think that you might find this thread that I started a few weeks ago very interesting.
    Go directly to this post if you want to download the latest version of the circuit.
  7. blocco a spirale
    Jun 18, 2008
    1,459
    369
    Splendid:)
  8. IcedFruits
    Jan 15, 2014
    84
    thanks for the link, will look ! my goal was just to driver a mosfet in a 5 volt circuit though !
  9. MikeML
    Oct 2, 2009
    5,451
    1,066
    Be advised that a real 555 will be marginal at a Vcc=5V. The LTSpice behavioral model is too simplistic to model this correctly. Get the 555 model that is on the LTSpice Yahoo group if you want a more realistic sim of a 555 powered from only 5V.
  10. IcedFruits
    Jan 15, 2014
    84
    thanks ! i will check the yahoo group model. also i think i have some CMOS TS555 chips, those work from as low as 2Volts, so i guess it wont be much of a problem. but thanks for advice ! :)
  11. t_n_k
    Mar 6, 2009
    5,448
    783
    The alternative linCMOS versions are claimed to work down to a 2V supply.
  12. blocco a spirale
    Jun 18, 2008
    1,459
    369
    You could also look at redesigning the output stage so that it can get closer to the supply rails and swing more voltage.
  13. IcedFruits
    Jan 15, 2014
    84
    u mean this ? that's the closest C1 gets to supply rails, and R4 remains to control current of C1.
  14. blocco a spirale
    Jun 18, 2008
    1,459
    369
    At the moment, you are losing a quarter the the supply voltage across the emitters of Q1 and Q2. If you swap Q1 and Q2 around (configure as common emitter rather than emitter follower), the output will be able to swing closer to the supply rails but you have to be careful because during switching transitions both transistors will be on at the same time which will cause short current spikes on the supply lines. You must also make sure that the base drive to the transistors is able to get close enough to the supply lines to ensure that each transistor can be turned fully off.
    The current spikes can be dealt with by adding a large decoupling capacitor across the supply lines to the transistors and by increasing the values of R5 and R7 a little. A common emitter stage after the output of the 555 should provide suitable base drive for Q1 and Q2.
  15. IcedFruits
    Jan 15, 2014
    84
    but with common emitter @ rails, probably due to opposite on effects to 555 clock, the voltage swing gets worse...... @ the meeting point of both collectors.
    also, in this configuration, both transistors don't get on at the same time either. can u please explain with schematic ?
  16. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    Nowhere do you say what your output current requirement is. A bipolar 555 can source/sink over 100 mA. If that's all you need, you can drive C1 directly without the two transistors for much better performance.
    ak
  17. crutschow
    Mar 14, 2008
    13,476
    3,362
    You need a separate 1k resistor from the output of the 555 to each transistor base. Otherwise both transistors will be on at the same time.
    Also you don't need R5, R6, and R7.
    And why is the resistance of V1 so high?
  18. IcedFruits
    Jan 15, 2014
    84
    originally only ~25-30mA. that requirement can already be met by 555 itself, just doing to the discussion for knowledge increasing purpose, to drive bigger transistors if want in future. optimization of the transistor configuration is the objective now.
    small signal BC r just for illustration purpose. pls ignore their numbers.
    they are pnp & npn..... anyways i will check with separate base transistors for any improvements. V1 is just some old rechargeable AA cells i have they don't give much high currents.
  19. crutschow
    Mar 14, 2008
    13,476
    3,362
    That's obvious from the schematic. Did I post something to make you think that I didn't understand that?
  20. blocco a spirale
    Jun 18, 2008
    1,459
    369
    As I said earlier, you need a common emitter stage between the output of the 555 and Q1 &Q2. It is essential that Q1 and Q2 are driven from an output that can swing close enough to the supply rails to ensure that each transistor can switch fully off while the other is fully on. I don't think that the 555 output can do this.
