It's definitely not a Kawasaki motorcycle...but could it be one of these ?
Safety Standard Certified Ceramic Capacitors/High Voltage ... - Murata
www.murata.com/products/catalog/pdf/c85e.pdf">Safety Standard Certified Ceramic Capacitors/High Voltage ... - Murata
What do you mean by "no reading on my analog meter"?
What do you mean by "check it out of circuit"?
You cannot infer much by testing a capacitor in-circuit or out-of-circuit.
A capacitor should read "open circuit" when tested out-of-circuit except when it is a high value capacitance greater than 1000μF.
I would guess that is a 2200pF or 0.0022μF cap.
You cannot use an Ohmmeter to measure capacitance.
Doesn't work unless you know what you are doing.Well I used it on my electrolytic caps to test if they were still good or not.
Ok, so anyways I found the value of the two caps and it turns out it's not the problem of why I don't have power on my power supply.. given everything is SMD and it's a SMPS I'm thinking about just chucking the whole board.Doesn't work unless you know what you are doing.
Can you provide the make and model of the projector?
