What is this?
Discussion in 'General Electronics Chat' started by MichaelKelley, Jun 29, 2013.
  1. MichaelKelley
    Jun 25, 2013
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Solar powered Coleman gas lamp.
    Backup for when you run out of gas.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    A solar powered lamp, what a great invention:p But Mr. Chippy is correct that the ting that is not a lamp. May be some sort of solar panel.
  4. Metalmann
    Dec 8, 2012
    700
    223
    That Coleman lantern is run by the propane cylinder. You can see the mantles.
    Why they have a solar panel above it....maybe some kind of prank. :confused:
    Unless, they have some LEDs mounted inside next to the mantles.
  5. LDC3
    Apr 27, 2013
    920
    160
    Probably camping gear that somebody neglected to take home with them.
  6. crutschow
    Mar 14, 2008
    13,481
    3,368
    You can see a wire with a connector hanging from the bottom of the solar panel, so it's not connected to anything.
  7. t06afre
    May 11, 2009
    5,939
    1,222
    Those lamp tend to be very hot. So hot that no LED will survive
  8. Metalmann
    Dec 8, 2012
    700
    223
    I know about that heat very well.;)
    I was thinking they may have used a solar panel to power LEDs inside the lantern....when it was not being fired by propane.
    I still have several of the older Colemans powered by white gas. I only have two that use propane.
    Probably the best fishing/survival lanterns ever created.:cool:
  9. Ron H
    Apr 14, 2005
    7,050
    657
  10. ErnieM
    Apr 24, 2011
    7,436
    1,625
    http://pinterest.com/Bikerbitc42012/survival-camping/
    You guys really have to learn how to use google's search by image. :D
  11. MrChips
    Oct 2, 2009
    12,624
    3,451
    Oh wait!
    This is to power your cell phone/iphone/ipod/ipad at night!
  12. t06afre
    May 11, 2009
    5,939
    1,222
    That could work if you also had LED lamp to light up the solar panel. Powered from the solar panel of course:rolleyes:
  13. Ron H
    Apr 14, 2005
    7,050
    657
    That's what the lantern is for.:D
  14. shortbus
    Sep 30, 2009
    4,092
    1,673
    Maybe the lamp is actually a hydrogen powered one instead of propane. And the solar panel is powering a HHO generator to keep it burning?
  15. mbohuntr
    Apr 6, 2009
    413
    32
    Finally... photovoltaic-dihydrogen monoxide generation is really catching on...:cool:
  16. Ron H
    Apr 14, 2005
    7,050
    657
    I thought it as called hydrogen hydroxide...;)
  17. Kermit2
    Feb 5, 2010
    3,847
    963
    I thought it was just rusty metallic hydrogen. Messy stuff!
