What is this?
Discussion in 'General Electronics Chat' started by timelessbeing, Nov 27, 2011.
  1. timelessbeing
    Jul 5, 2011
    18
    I found this little guy in a box of random parts.
  2. MrChips
    Oct 2, 2009
    12,635
    3,454
    If you can say what gadget the board is out of or if you can send a wide view photo of the board that may help.
  3. timelessbeing
    Jul 5, 2011
    18
    Unfortunately that's all I have. Possibly a printer or scanner. There is a stamp on the back of this PCB fragment that says CMKD-P3X and a date 2003.6.2. I looked it up and came up with nothing.
    Some kind of EPROM?
  4. MrChips
    Oct 2, 2009
    12,635
    3,454
    Then my guess is that it is the sensor from an optical mouse.
  5. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    It looks like some light sensitive sensor.
    This company has a lot of those "see through" chips:
    http://www.taosinc.com/
    Bertus
  6. timelessbeing
    Jul 5, 2011
    18
    I'm positive I've never taken apart a mouse. But the part could have many uses.
  7. timelessbeing
    Jul 5, 2011
    18
    Good eye! It looks a lot like their ambient light sensors.
    I wonder if there's a part number on the bottom.
  8. thatoneguy
    Feb 19, 2009
    6,357
    718
    Dark strip looks like a fingerprint reader.
  9. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    I think that the black strip is to small for a fingerprint reader.
    Where the fingerprint readers available in 2003?
    Bertus
  10. timelessbeing
    Jul 5, 2011
    18
    The PCB definitely was not exposed to user fingers.
  11. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It's a simple light sensor, probably with "light to frequency" output. The sensor component only has 2 wires going to the chip, so it is a simple monochrome photodiode or LDR.
    If you power the board up you will probably find one of the chip pins is a frequency output that changes freq according to light level.
  12. Adjuster
    Dec 26, 2010
    2,147
    300
    The device we are assuming to be a sensor appears to have only one bond wire contacting it, and a common connection. Is it not more likely to be a single photodiode?
    Edit: Oops, someone got there an hour ago.
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    From what little I can figure out, the board came from a DVD player.
    I believe that the IC you have there was used to determine the position of the laser head.
  14. thatoneguy
    Feb 19, 2009
    6,357
    718
    I stated that it "looks like" the fingerprint readers found in notebooks and other electronics today. Not enough connections to actually be one, though I should have added that in my post above.
  15. timelessbeing
    Jul 5, 2011
    18
    I never took apart a DVD player.
  16. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Interesting! Do you know that or it it a guess? I've never seen a sensor of this type used for laser head positioning, normally they position by finding focus on the ident track on the DVD and some units may have an optical interruptor sensor on the mechanicals.
    I still think it's an ambient light sensor (and yep that's a guess!). :) Some appliances have autodimming of the display at night and the ambient light sensor is used for that. In which case it probably would have been on the front panel PCB with a little window.
  17. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I agree with Sgt. Wookie and The_RB. It could be used in a DVD player, CD player, or it could be used to calibrate a laser printer. I've seen them on all sorts of electronic devices, all of which have something to do with a laser. Optical Mice usually have one built into a larger chip, used to decode the signal. I haven't once seen one in a mouse separate from the other components. My money is on the CD player or the calibration circuit for a laser printer.
  18. timelessbeing
    Jul 5, 2011
    18
    There's a very good chance it came from a laser printer. I DO remember disassembling one. Since there's an IC, does that mean output would be digital?
  19. thatoneguy
    Feb 19, 2009
    6,357
    718
    No, just different voltages out on the two wires connected to it depending on which horizontal "ribbon cell" section the laser hits. I'm assuming that if you look very closely, you'll see hundreds or more small lines across the narrow side from top to bottom. Each is a photocell that will output a slightly different voltage when illuminated, so the output of it will "say" where the light is pointed at on it by a different voltage.
  20. timelessbeing
    Jul 5, 2011
    18
    I see, so it might be useful for trying to align something.
