Hello All
I need help in identifying this item. This is for a battery charger. The silver plate is attached to the negative cable. The wire that goes to the top component has been heated so bad that it burnt off the insulation. That wire in turn comes from a transformer? I do not know much about these and could use some help. This is a 2/10/40 amp charger.
