What Is This?!
Discussion in 'General Electronics Chat' started by hazim, Sep 17, 2009.
  1. hazim
    Thread Starter Active Member
    Jan 3, 2008
    419
    13
    This thing was attached at the top of the rear glass of our Oldsmobile car. It seems to be a board with integrated circuit... but no electronic components are apparent. It was not connected to anything else by wires or anything. What would be this?
  2. Von
    Oct 29, 2008
    65
    Part of a rear window defogger?
    You may also see fine lines in or on the glass.
    How about part of the radio antenna?
    [not-so]Secret government tracking device?:D
  3. hazim
    Jan 3, 2008
    419
    13
    No it's not connected to the defogger or anything else. Those fine lines of the defogger are working well without this device. And the antenna is far enough from this device and it is inside the car... it is not correlated with the antenna....
    Do you think it's a spying device?:eek::D.........:confused:
  4. ke5nnt
    Mar 1, 2009
    384
    15
    What's the other side look like?
  5. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    It is a 33199 unit. In other words I have no idea. Ask a car repair shop?
  6. t06afre
    May 11, 2009
    5,939
    1,222
    If you found it in an American built car it is probably not a piece with modern technology, so relax ;)
  7. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    It's probably for an optional accessory, possibly not required in all countries.
  8. t06afre
    May 11, 2009
    5,939
    1,222
    It could be some sort of antenna. Maybe for the central lock system, the car radio, or perhaps a GPS unit that you do not have in your car. The best thing is to ask your local car repair shop..
  9. ELECTRONERD
    May 26, 2009
    1,146
    16
    If you have a newer car, it could be something to do with a sattelite antenna. When was the car built?
  10. gerty
    Aug 30, 2007
    1,154
    304
    Looks like it could be the interior part for a through the glass cell phone antenna.
  11. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Maybe it's a UFO detector :)
  12. hazim
    Jan 3, 2008
    419
    13
    ke5nnt, it's almost the same. All your guesses are possible... ELECTRONERD, the car was built in 1991, it's old...and it is with us from about 5 years
  13. ELECTRONERD
    May 26, 2009
    1,146
    16
    Then it definitely wouldn't have a sattelite antenna.
