What is this white thing?
Discussion in 'General Electronics Chat' started by axelman0, May 28, 2010.
  1. axelman0
    May 28, 2010
    The current goes from the blue wire through the fuse, then to a contact under "4" on the white thing, then through a capacitor into "1" and back out the white cord. "2" and "3" are also joined by a capacitor, with a black wire also on one end of the capacitor and an orange wire on the other that both go to the rest of the circuitry. What exactly is going on in that big white thing in the center and how does it effect the current flow? How does it relate "1" and "4" to "2" and "3", and what does that arrow mean?
  2. Markd77
    Sep 7, 2009
    2,803
    594
    Looks like a bridge rectifier to me. Have a look on Wikipedia for a good explanation.
  3. davebee
    Oct 22, 2008
    539
    46
    It looks like it could be a fullwave diode bridge.
    I can't quite see the marking on it - do two pins show little sinewave cycles, and the other two pins show "+" and "-"? That would be a clue that it is a bridge rectifier.
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    The picture is rather blurry.
    The markings on the part can not be read.
    Is it possible to make a SHARP picture of the thing?
    Does your camera have a close-up modus?
    If so retry to make the picture in this mode.
    Did you try to measure on the part?
    It could be a brigde-rectifier as the others say, but also a common mode filter.
    Bertus
  5. t06afre
    May 11, 2009
    5,939
    1,222
    Ok this is somewhat (if not purely) speculative. But I think it is an inductor. This is due to the round shape. Could it be a common mode choke?
  6. axelman0
    May 28, 2010
    I'm sorry my camera phone couldn't get that close up, the markings are "4" on the top left, "1" on the bottom left, "3" on the top right, and "2" on the bottom right, with an arrow that points from "1" and "4" towards "2" and "3", and those are the only markings
  7. axelman0
    May 28, 2010
    Ah yes it is a diode bridge, there are actually several different types all throughout the machine, thank you all very much. There doesn't appear to be a way to make a thread as solved...
