No, a Diesel bus.Is it a hybrid bus? We have hybrid buses in my area, but they say hybrid on them and the roof area is extra thick, as if they're keeping the energy storage devices in the roof.
I'm guessing the bus, like many ocean going cruise liners and locomotives, has a diesel engine which runs a generator which provides power for an electric motor. The ultra capacitor stores energy while the vehicle is idling, and provides current to accelerate or climb hills.No, a Diesel bus.
I don't think the bus is Diesel-electric. I would think they would say so on the outside in big print.I'm guessing the bus, like many ocean going cruise liners and locomotives, has a diesel engine which runs a generator which provides power for an electric motor. The ultra capacitor stores energy while the vehicle is idling, and provides current to accelerate or climb hills.
Why does the rate at which the current is changing such a big deal? I would think it would be the magnitude of the current itself (dq/dt) that would matter much more.There is too much current for batteries to absorb safely, so it goes into a supercap array that can handle a much greater di/dt.
Ohhh I like that. Lower weight, higher reliability.Its used to start the bus since it reduces the battery count from 4 to 2.
So, how does it do this? By lowering the output resistance of an existing battery? By doubling the battery voltage?Its used to start the bus since it reduces the battery count from 4 to 2.
I think that you can find the answer here:So, how does it do this? By lowering the output resistance of an existing battery? By doubling the battery voltage?
I think older buses used compressed air to start the engine. I assume this is the modern equivalent?
Yes! I will need some time to digiest it, though.I think that you can find the answer here:
http://www.koldban.com/Kapower_Information_Center_s/28.htm
Thread starter | Similar threads | Forum | Replies | Date |
M | ultra-low voltage continuity tester? | Test & Measurement | 37 | |
E | Ultra thin soldering iron | General Electronics Chat | 3 | |
B | Ultra Fast Oscillator | General Science, Physics & Math | 17 | |
B | Ultra Low Noise Linear AC to DC Regulator Design | Power Electronics | 12 | |
H | Precision Ultra Low Power High-Side Current Sense | Analog & Mixed-Signal Design | 17 |
