What is this TI component?
Discussion in 'General Electronics Chat' started by jb0x2d1, Apr 5, 2013.
  1. jb0x2d1
    Apr 5, 2013
    [​IMG]What in the world is this TI component (bottom right corner)? It clearly has a TI mark on it but I've searched ti.com and elsewhere and I can't find anything on it.
    http://tinypic.com/r/o8xt0y/6
  2. timescope
    Member
    Dec 14, 2011
    298
    44
    It could be an ASIC ,application specific integrated circuit. What application is the board used in and what do the push buttons do ?
    Timescope
  3. jb0x2d1
    Apr 5, 2013
    It is the keychain fob to my car. The buttons unlock, lock, trunk and panic.
  4. absf
    Dec 29, 2010
    1,493
    374
    I'd guess it's a RF remote control of some sort (315 MHz may be)...
    Any printed coils on the flip side of the PCB?
    Allen
    [edit] Oops! I am typing too slowly.
  5. GopherT
    Nov 23, 2012
    6,339
    4,084
    The coil ( matsushita / Panasonic) is in the upper right 315Mhz.
    The chip is a rolling code security chip to mate with the vehicle and send the appropriate digital signal sequence to the receiver in the vehicle. It is an application-specific chip and you will not likely find a replacement.
    absf likes this.
  6. THE_RB
    Feb 11, 2008
    5,435
    1,305
    It will just be a TI 14 pin microcontroller, probably a 430 series, with application specific code and code protected.
    You won't be able to buy one.
    absf likes this.
  7. MrChips
    Oct 2, 2009
    12,652
    3,461
    Yes, the first thing to do is to trace where PWR and GND are connected.
    Is PWR on pin-1 and GND on pin-14?
  8. jb0x2d1
    Apr 5, 2013
    I don't know much about this stuff but I know enough to ask this: if I start poking around with my multimeter reading resistance in order to determine which pins go where, do I risk damaging anything (assuming it isn't damaged already)? There is only so much I can see.
  9. MrChips
    Oct 2, 2009
    12,652
    3,461
    I think the point is this is a customized chip and you will not be able to to purchase it.
    You may be able to reverse engineer the circuit and find a microcontroller from TI that matches the pinout. But you will still need to program the chip to the right specifications which is no easy task.
  10. Dodgydave
    Jun 22, 2012
    5,171
    777
    absf likes this.
