what is this symbol?
Discussion in 'The Projects Forum' started by onlyvinod56, Feb 8, 2009.
  1. onlyvinod56
    Thread Starter Active Member
    Oct 14, 2008
    362
    Hi everyone,
    Iam attaching an image. just check it. what is that symbol?
    Iam also attaching a pdf file. How can the frequency of the output can be decided?
  2. Alexei Smirnov
    Jan 7, 2009
    43
    Must be AND component with schmitt trigger on each input and inverted output...
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    Since one input is always high, it is an inverter with a schmitt-trigger input.
    It is one gate of a CD4093 quad 2-input NAND Schmitt trigger IC.
  4. onlyvinod56
    Oct 14, 2008
    362
    okm thank you.
    How can i control the frequency with that IC?
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    Look up CMOS oscillators that use the inverter function. Fairchild Semi AN-118 is a nice source. It can be done with a single resistor, capacitor, and gate.
    John
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    As AudioGuru suggests, it's likely a 4093 quad NAND Schmitt trigger; the Philips datasheet would be HEF4093B.
    Schmitt triggers are generally used to "square up" signals. Just looking at that one gate, the threshold levels for the inputs would be 1/3 Vdd and 2/3 Vdd.
    If the upper input were held high as shown, and the lower input started off low, the output would be high until the lower input exceeded 2/3 Vdd, or 8v. Then the output would go low until the lower input fell below 1/3 Vdd, or 4v.
    The NE566 function generator is a discontinued part. You'd have to use a different timer/oscillator IC; a 555 timer might be a substitute - but you couldn't use the 3.3v Zener or the rest of the oscillator circuit as shown.
