What is this part?
Discussion in 'General Electronics Chat' started by boatsman, Sep 10, 2015.
  1. boatsman
    Thread Starter Senior Member
    Jan 17, 2008
    165
    394
    Can someone please tell me what this part is, what is its function, how can I check if it is OK and what can I substitute for it? The part in question is in series with the phase input to a heating coil in the base of a Tomado rice cooker. The unit is rated at 700Watts at 220VAC . IMG_20150909_201754.jpg IMG_20150909_201754.jpg IMG_20150909_201754.jpg
  2. Kermit2
    Feb 5, 2010
    3,838
    961
    Looks like a self resetting breaker or a thermal fuse. When it gets too hot it opens and current stops until it cools off
    boatsman likes this.
  3. shortbus
    Sep 30, 2009
    4,082
    1,663
  4. boatsman
    Jan 17, 2008
    165
    394
    Thank you Kermit2 and shortbus for replying. Should I get a resistance reading from it? I get no indication in either direction so can I assume that the part needs to be changed?
  5. alfacliff
    Dec 13, 2013
    2,449
    428
    thats the failure for them, they get too hot and open up. better rthan burning down the house.
  6. cmartinez
    Jan 17, 2007
    3,695
    2,746
    If the fuse were well, you'd get a continuity reading on either direction. But that fuse is obviously blown, just get an equivalent temperature replacement as shortbus has suggested.
