What is this MOSFET?
Discussion in 'General Electronics Chat' started by magnet18, Feb 20, 2011.
  1. magnet18
    Thread Starter Senior Member
    Dec 22, 2010
    1,232
    125
    I was taking apart the tv I'm getting parts from for my plasma speaker, and I found what i think is the MOSFET that drives the fly-back.
    I was trying to find the specs for it and after about half n hour of searching i couldn't find the datasheet, just tags of it in other sheets that said nothing about it.
    Its labeled D1556, I attached a pic.
    Anyone know where I could find the specs for this?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    I think it is a NPN planar transistor.
    See datasheet for more info.
    Bertus
    magnet18 likes this.
  3. magnet18
    Dec 22, 2010
    1,232
    125
    Thanks Bertus, thats it :)
    I think its powerful enough for my needs too :D
  4. marshallf3
    Jul 26, 2010
    2,358
    201
    High power horizontal output with integral damper diode. Beats the 1555 by a mile.
  5. kkazem
    Jul 23, 2009
    160
    27
    Hi all,
    Yes, this is almost certainly a 2SD1556. This is a Japanese (actually, far east in general) numbering system for semiconductors unlike the US JEDEC Standard Part Numbering for Diodes & Transistors (1NXXXX, 2NXXXX).
    The Japanese started the 2SAXXXX, 2SBXXXX, 2SCXXXX, & 2SDXXXX numbering system back in the 60's I think and most far-east products use these to this day. Note that it doesn't include ICs. The markings are almost always the part number with the 2SY left out, where the Y is the first letter after the initial characters 2S.
    Of course, there are always exceptions. For example, a house-marked transistor. This is where a company like ON-Semi will mark the part with any number you want, other than a standard part number. I don't know if that goes for Far-East transistors and Diodes or not. Anyway, since the far east parts leave out the 2S, the rest is probably fair game. This is often done for two reasons. First, to throw off competitors trying to reverse engineer a design and the other reason is that a firm may have a special part numbering system and they prefer to have all their semi's marked with their own part numbers, at least wherever possible.
    Regards,
    Kamran Kazem
    kkazem
  6. magnet18
    Dec 22, 2010
    1,232
    125
    So, will this not work unless the collector-emitter voltage is at least 1400V?
  7. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    The transistor will work fine on lower voltages for Vce.
    The 1400 Volts is a test condition.
    The Hfe is tested at a Vce of only 5 Volts.
    Bertus
  8. debe
    Sep 21, 2010
    955
    185
    1400v is the max voltage C/E it can handle.
  9. magnet18
    Dec 22, 2010
    1,232
    125
    Hmm, then I'm confused.
    Why wouldn't the following circuit work?
    :confused:
  10. debe
    Sep 21, 2010
    955
    185
    I am asuming there is a common conection betwean B1 & B2 negative?
  11. magnet18
    Dec 22, 2010
    1,232
    125
    Nooooo....
    I'm guessing I should do that...
  12. marshallf3
    Jul 26, 2010
    2,358
    201
    Revise your schematic to indicate a true 2SD1556 and it needs some current to drive but not much Vbe.
    All around one of the best horizontal output transistors made for that frequency but heat sink it with a thick mica washer & plenty of thermal grease or it'll try to arc back. They are not bulletproof. Find an old TV schematic where one was used.
  13. magnet18
    Dec 22, 2010
    1,232
    125
    arc back?
    :confused:
  14. debe
    Sep 21, 2010
    955
    185
    Since there is a huge amount of different Horz O/P transistors the chance of finding a TV circuit with a 2SD1556 transistor init is going to be remote especialy if it was in a monitor. But most Flyback? Horz O/P circuits are basicly the same. I will post several TV Flyback circuits.
      File size:
      305 KB
      15
      File size:
      280.8 KB
      10
      File size:
      256.8 KB
      14
      File size:
      296 KB
      13
      File size:
      324.6 KB
      10
      File size:
      319.8 KB
      10
  15. debe
    Sep 21, 2010
    955
    185
    An a couple more.
      File size:
      310.5 KB
      16
      File size:
      288.2 KB
      15
