What is this connector for Samsung SyncMaster?
Discussion in 'General Electronics Chat' started by saloma, May 29, 2014.
  1. saloma
    May 29, 2014
    Hi!
    I got myself into a tricky situation with my Samsung SyncMaster monitor, and I think I need a new connector, that looks like this. But I cannot find the name of it... Can you help me? : ) The serial number on the cable is B12810DL (doesn't match to anything when googling).
    My problem is that I somehow spilled red wine (...) inside the touch panel under the monitor and it's not working anymore. I assume it's because the cable/connector was damaged during this messy situation : D
    -Sanna
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    I doubt that the connector is the problem.
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
    +1... "HIGHLY" doubt it.
  4. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,685
    1,297
    +10
    The residue left behind by evaporated wine can be enough of a conductor to mess up circuits. Here is how I've resurrected 2 cell phones plus other misc stuff:
    Assuming that a part isn't fried, either remove the board or get it positioned such that a liquid running off if it will not drip onto anything important. Then wash the area with rubbing alcohol. It, too, can leave a residue, but not as bad as wine. The best way is to use a small squirt bottle with a thin nozzle, a low pressure version of hosing off a driveway. Wash, let sit for 10 minutes, repeat 4 times.
    ak
  5. saloma
    May 29, 2014
    Thank you for your tips! Sadly this didn't do the trick, neither could the guys at a computer repair store fix it without spending too much of my money. Still trying to figure out how to tackle this problem, turning the screen on without a power button seems unlikely, since the applets found online require the screen to be switched on and running electricity before turning it off and on again.
    Then again, a new 27" screen sounds nice too!
