What is this board?
Discussion in 'General Electronics Chat' started by athulascc, Jul 5, 2015.
  1. athulascc
    Aug 15, 2014
    88
    I guess this is SOP44 to DIP36 microchip programmer.
    Am I correct?
    if yes anyone can help me to make the Schematic like this?
    Advice,,?/
    thanks
  2. GopherT
    Nov 23, 2012
    6,308
    4,029
    Yes, it is for bread boarding a surface mount chip. The pins and board make the chip look like an Through-hole component. As you said, it also lets you put the programming pull-up resistors in place so everything can be done on a breadboard.
    athulascc likes this.
  3. athulascc
    Aug 15, 2014
    88
    yes. But I do not know the pin configuration, I hope to connect 4 programming pins and GND and VCC according to DIP36 package and SOP44.
    will it work?
  4. athulascc
    Aug 15, 2014
    88
    or, if anything need to do more tell me, I can see Diode there, But why we need diode?
  5. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    One little remark:
    Bertus
  6. GopherT
    Nov 23, 2012
    6,308
    4,029
    There is a model number along the pins 23 to 35 on the board. Google that number with the word, "datasheet" and hopefully you will find what you need. I cannot make out all the digits of your model number.
    Good luck.
  7. ErnieM
    Apr 24, 2011
    7,436
    1,626
    This looks like an adapter board with some extra features.
    If you already haveonetrace it outtomake the schematic.
    The best place for info is the place you got it, or even better the place that made it.
    Worst case use Google search by image to see who has it or who made it.
  8. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    The marking; "29F" might suggest a parallel FLASH memory chip, but the "29L" underneath it doesn't match any I can think of.
    GopherT likes this.
  9. WBahn
    Mar 31, 2012
    18,087
    4,917
    My guess is that the 29L is a lower voltage (3.3V?) version of the 29F series (5V?).
  10. wayneh
    Sep 9, 2010
    12,379
    3,236
    This thread's title is very misleading! :(
  11. JWHassler
    Member
    Sep 25, 2013
    204
    34
    Glad someone else ran with that 'broad' ting.
    It's a Nintendo adaptor... see here
  12. ian field
    Oct 27, 2012
    4,447
    791
    I'd go along with the "L" denoting low voltage, part numbers are typically something like: 020 or 040. There are sometimes variants like a parallel FLASH memory with a protected boot area or somesuch.
  13. athulascc
    Aug 15, 2014
    88
    MrSoftware likes this.
  14. athulascc
    Aug 15, 2014
    88
    above 3 images will help you. so now I am going to download datasheets of relevant ICs and Connect pins which have same names. will it work, but probably then some pins will leave alone, so what to do?
    Any idea about schematic. or any way to search it in google. I mean a keyword for search?
    thanks
  15. thief
    Jun 15, 2016
    Hello my friends. Where i can find this board to buy? Thanks
  16. Techno Tronix
    Member
    Jan 10, 2015
    140
    10
    You can check with some PCB manufacturer or PCB supplier. You can also purchase it online. Just be clear with your requirements.
  17. thief
    Jun 15, 2016
    I tried to found this adapter at buyicnow, ohspark, and others sites. But i cant found. I don`t have the project files to send to pcb manufacturer do to me.. do you have the files? thanks for answer me
  18. gunner79
    Oct 5, 2016
    where I buy this adapter? I find no adapter for the memories 29l3211! Thanks in advance!
