what is this board called!
Discussion in 'Wireless & RF Design' started by aj_silverthunder, Nov 16, 2009.
  1. aj_silverthunder
    Thread Starter Active Member
    Jun 6, 2009
    116
    what is this board called which is in the image given below ,what is it made up of
    ,is it a copper board,and what type of technique is that,how does this circuit gets connected to other components very precisly!!!
    BY WHICH MATERIAL IS THAT TRACKS MADE OF,IS IT SOLDER WIRE!
  2. KL7AJ
    Nov 4, 2008
    2,047
    295
    It's copper clad epoxy glass PCB material. You can etch it chemicallly, or attach small copper pads to it in the "Manhattan" method, or even cut traces with a Dremel or Xacto knife. Its "precision" is determined by your technical skill. :)
    Eric
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    It is a double sided PC Board, after etching. Most likely with Toner Transfer/home made, as there isn't a solder mask or component labels.
    There are software packages around that will create the PCB artwork from a schematic, or you can use a PCB CAD program to draw a board from the schematic. You may want to start out single sided, however.
    The Actual Board appears to be some sort of BASIC Stamp SX device, with the serial port I/O, and the Ubicom SX uC. The bottom side of the board is filled with traces as well.
  4. aj_silverthunder
    Jun 6, 2009
    116
    does the board conducts electricity or non-conductive
  5. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    In this picture, the silver traces conduct electricity while the yellowish portion is nonconductive.
  6. aj_silverthunder
    Jun 6, 2009
    116
    what is that silver tracks made by,i guess solder ! and what is that board made of!
  7. BMorse
    Sep 26, 2009
    2,675
    234
    The tracks are plated copper traces..... The board is probably one of these but most likely an FR4 (Fiber Glass)
    Material Used for Printed Circuit Board (PCB)
    FR406, FR4, FR04, IS410,Nelco , Polyimide, Rogers, Duroid, VT45 and47. FR-4 printed circuit board material is most commonly used.
  8. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    The silver tracks are copper that are plated with tin or tin/lead.
