What is the wrong in assembly code for 16f84a?
Discussion in 'Programmer's Corner' started by Nec, May 4, 2009.
  1. Nec
    Nov 21, 2008
    6
    Hi everyone, my problem is that I write a assembly program for 16f84a but this program is not work there is no transition from bank0 to bank1.I write a simple program to see problem easily but same thing happened again.
    ---simple program---
    PORTA EQU 0x05
    PORTB EQU 0x06
    TRISA EQU 0x85
    TRISB EQU 0x86
    STATUS EQU 0x03
    ORG 0x00
    CLRF PORTA
    CLRF PORTB
    BSF STATUS,5
    MOVLW 0x00
    MOVWF TRISA
    BCF STATUS,5
    MOVLW 0x03
    MOVWF PORTA
    END
    Normally, move from bank0 to bank1 and program all pins of porta as output and return to bank0 and then it makes second and first pins of porta high output.Right but it does not happen, it gives an error message "Register in operand not in bank 0. Ensure that bank bits are correct." for trisa(I use mplab 8.10).I couldnot see the mistake in the code :S someone can help me.Thanks
