what is the usual power factor of a 32 Amp main switch ?
Discussion in 'General Electronics Chat' started by HoopHoop, Oct 17, 2016.
  1. HoopHoop
    Aug 22, 2016
    24
    the substation is kept in a normal room temperature 25-30 degrees (in India). I just wanna know what usually is the power factor. Maybe there are other parameters that u need to tell me the power factor but i just want to know what is usually the power factor? is it about 0.9??
  2. crutschow
    Mar 14, 2008
    13,487
    3,371
    You mean the power factor of typical residential loads?
  3. HoopHoop
    Aug 22, 2016
    24
    not exactly residential. bigger than that. 3 phase 200 Amp main switch is the largest substation. maximum load is around 285 KW in the whole compound (mainly due to central ac).
  4. tcmtech
    Nov 4, 2013
    2,110
    1,750
    .5 - 1 depending on load.
  5. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    There is no "usual" power factor. Your power company can probably give you an idea because most will charge a premium if your power factor is significantly less than 1.
