what is the use of this resistor??
Discussion in 'The Projects Forum' started by onlyvinod56, Oct 24, 2009.
  1. onlyvinod56
    Thread Starter Active Member
    Oct 14, 2008
    362
    hello everyone....
    - first check the attachment please.....
    - it is an inverter....
    - 220 ohm resistors are connected from pins 10 & 11 to the gates of the mosfets...
    - IC 4047 is given from a 12v supply.... so the output voltage pulse at 10 & 11 will be 12 (or less but not more...right)
    - see the next attachment...the Vgs of IRF 540 is 20v...
    if i give the 12v directly to the mosfet...then also it'll work in safe range
    then what is the use of 220ohm....
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    The 220 ohm resistors prevent the Mosfets from oscillating at a VHF frequency due to their gate capacitance and inductance of their input wires. The 220 ohm resistors should be mounted as close as possible to the gate pins of the Mosfets.
  3. onlyvinod56
    Oct 14, 2008
    362
    thankyou audioguru...
    how can i calculate the resistor value for different mosfets at different applications......
    what parameters i have to concentrate.....???
    any example.......please....
    thankyou
  4. shortbus
    Sep 30, 2009
    4,095
    1,685
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  6. onlyvinod56
    Oct 14, 2008
    362
    thankyou shortbus.....
    my doubt is cleared
  7. onlyvinod56
    Oct 14, 2008
    362
