What is the transfer function of this LC low-pass filter?
zhaojia
Joined Nov 23, 2007
7
I want to get a transfer function of the following LC low-pass filter.
And, I want to know how it's cut-off frequency is derived.
Thanks for your help.:)
An LC low-pass filter:
http://www.williamson-labs.com/images/filters-lc.gif
(The first one, the Ui(jw) is at left for input and Uo(jw)) is the output at right.)
The first circuit.
What is the expression for G(jw) = Uo(jw) / Ui(jw)?
And What is the cut-off frequency wc?
{the value wc makes G(jwc) = 1/sqrt(2) * G(j0) }
zhaojia
Joined Nov 23, 2007
7
Sorry.
This is NOT the correct concept of cut-off frequency.
The cut-off frequency, in fact, is a corner frequency f0 at which the attenuation characteristics emerge.
It can be derived form the mathematically reform.
GS3
Joined Sep 21, 2007
408
http://en.wikipedia.org/wiki/Cutoff_frequency
In electronics, cutoff frequency or corner frequency is the frequency either above which or below which the power output of a circuit, such as a line, amplifier, or electronic filter is 1/2 the power of the passband. Because power is proportional to the square of voltage, the voltage signal is SQRT(1/2) of the passband voltage at the corner frequency. Hence, the corner frequency is also known as the −3 dB point because SQRT(1/2) is close to −3 decibels. A bandpass circuit has two corner frequencies; their geometric mean is called the center frequency.
The Electrician
Joined Oct 9, 2007
2,970
Imagine that the inductor were replaced by a resistor, R1, and the capacitor were replaced by another resistor, R2. Then you would have a voltage divider, and Vo/Vi would be given by R2/(R1+R2). If you replace the resistance of R1 by the impedance of the inductor, j w L, and the resistance of R2 by the impedance of the capacitor, 1/(j w C), the formula for the voltage divider will become the transfer function you want, namely ZC/(ZL+ZC). You will have to do some algebraic simplification to get it to look like what you would find in a book.
