what is the reason behind voltage regulator ic is not functioning correctly
Discussion in 'General Electronics Chat' started by etech7, Nov 14, 2015.
  1. etech7
    Jun 9, 2015
    29
    I made a project where two 6V relay is supplied from a 9v regulated dc supply. this dc supply is made up with 12V transformer, bridge rectifier, 100uF filtering cap, LM 7809 and a 10nF cap.
    when no relays are energized output voltage is nearly 9v. when one relay is energized voltage drops to nearly 7v. and when both relays are energised voltage drops to nearly 5v. each relay is driven by bc547 transistor with 1k base resistor. is this normal? or is regulator damaged? will it be fixed if I replace it with new one? what should I do to get constant 9v output without modification at relay side?
  2. Alec_t
    Sep 17, 2013
    5,972
    1,135
    What are the relay coil resistance values or current ratings? What is the transformer VA rating?
    Post a schematic.
    Ramussons likes this.
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    My first impression is that the filter capacitor is way to small.
    Try a 1000 uF capacitor over there.
    Bertus
  4. etech7
    Jun 9, 2015
    29
    coil resistance is 106-107 ohm on my meter check. current rating unknown. it is written on its body that "SRU-06VDC-SL-C"
    I don't know the va rating also. all I know its 230/12 v transformer. but I think its va is not much a problem because secondary voltage remains unchanged whatever ralys do. I am not able to upload it's schematic right now.
  5. etech7
    Jun 9, 2015
    29
    okay. I will replace that cap and notify you what happened. thanks for your attention. :)
  6. MikeML
    Oct 2, 2009
    5,451
    1,066
    Not gonna help if the voltage upstream of the regulator doesn't sag.
    You really, really need to post a schematic...
  7. etech7
    Jun 9, 2015
    29
    ok, 1000 uF cap method failed. nothing change! here is the schemetic.
  8. MikeML
    Oct 2, 2009
    5,451
    1,066
    What are the resistances of the relay coils?
    I'm guessing that the 7809 is miswired, or defective.
  9. Dodgydave
    Jun 22, 2012
    5,153
    770
    What's the voltage across the 1000uf cap at the input to the 7809, with and without relays energised?
  10. etech7
    Jun 9, 2015
    29
    Mmmm... Perhaps... 106 or 107 ohm, coil resistance by meter check. another point should note here that when i installed the regulator first time it's output was slightly above 9V. but now it is 8.88V on no load. and around 5V drops on it when both the relays are excited.
  11. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    Measure the voltage at the input and output of the regulator with one relay energized.
    What are the current ratings for the regulator and the transformer?
  12. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    I have rotated, scaled, cropped and changed the perspective using the gimp:
    I do not see any Back-EMF diodes on the relays.
    Bertus
  13. etech7
    Jun 9, 2015
    29
    Primary = 236V
    Secondary = 14.4V (Idle)
    Secondary = 13.4V (One reay), 13V (Both relay)
  14. Dodgydave
    Jun 22, 2012
    5,153
    770
    Then its the regulator at fault, or its wired wrong.
  15. etech7
    Jun 9, 2015
    29
    Thanks for the correction. mistakenly I forgot to draw back emf diodes. I used one diode for one relay and another is just left alone. what if i don't use those diodes by the way?
  16. spinnaker
    Oct 29, 2009
    5,076
    1,176
    I wish people would put a tenth of much effort into posting their schematics the first time as you put into fixing them. This is the second one you had to fix today and neither OP thanked you so I am doing so. Thanks for your efforts Bertus.
    Edit: so you did get a thank you on this one while I was posting! Nice to know when you are appreciated. :)
  17. spinnaker
    Oct 29, 2009
    5,076
    1,176
    Do you have a scanner? Just place the drawing on the scanner next time.
    Or better download something like DipTrace. It is easy to use. ExpressPCB is probably easier but DipTrace has more features.
  18. spinnaker
    Oct 29, 2009
    5,076
    1,176
  19. etech7
    Jun 9, 2015
    29
    At last a conslusion. But I don't understand why the regulator go waste? what if I will be replacing it again and again?
  20. dl324
    Mar 30, 2015
    3,377
    651
    The back EMF could damage the transistors.
    If the AND gate you're using is 7408, you're over stressing the part. Max VCC is 5.5V. It will tolerate 7V (non-operating).
