Dear DGElder, DrAI, NSASpook, and AnalogKidDon't think so. Equal and opposite with respect to an arbitrary internal reference point is not the same as equal and opposite in the outside world. Also, while "opposite phase" is defined as 180 degrees in balanced audio, that is not automatically true everywhere else in this universe. (Standard disclaimer: these conditions do not necessarily apply on Mars.)
In post #1 the TS confuses voltages with respect to an internal reference point, with external voltages measured with respect to something (anything) else. After 20 posts, the two still are not the same.
ak
All the quite valuable discussion you put in here for the benefit of less knowledged people like me is quite admirable and awe inspring really. Especially DGElder and DrAI is amazing. And we have gotten to possibility of 180d phase difference between capacitor plates relative to absolutely equal balanced material point if I am not reading it all wrong.
As AnalogKid, Jony130, CMartinez mentioned that I must take measurements relative to some other reference, I made a simple new simulation below. (Proteus does not provide differential graphs, and my free DoCircuits account is limited to 10 parts only. Excuse my cheapness pls).
Tried making a +10V reference here relative to earth ground, with minimal current flow. As people mentioned that meters need a closed circuit to measure anything, otherwise we would get just 0V. Which I really did on bench. AC source ampl is 10Vpp. Both caps are 1uF, top resistor 100ohm, bottom resistor 20MOhm. Leftmost DC voltmeter is VMeter00, next is Vmeter01. Hopefully in correct order, some simulation curves for 1Hz, 10Hz, 50hz, 100Hz, 1kHz, 10kHz, 50kHz, 75kHz, 100kHz are below.
Starting with 1Hz:
10Hz:
50Hz:
100Hz:
1Khz:
10KHz:
50KHz:
75KHz:
100KHz:
Now relative to both 10V line and ground we see no phase shift in any of these frequencies. Just for some fresh breath from high math could someone care to take a stab at what's going on here. I did not yet test this on bench, and yes simulators do have limitations. This one warns about entering virtual resistors on (+) leads of each voltmeter.
For bench test I will not use a signal generator. But generate sine wave from an op amp circuit, so everything including PC meters will be totally independent from power lines, if that helps. Will share results here.
With my sincere respects to masters here.
