What is the ratings of this motor???
Discussion in 'Off-Topic' started by Lightfire, Oct 27, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    My father gave me this motor. My father said he got it from laminator.
    So, here's the picture
    somebody tell me what are the ratings of the above motor, pls.:D
    Catapult:D:D:D
  2. wmodavis
    Oct 23, 2010
    737
    150
    The ratings are very low.
  3. Lightfire
    Oct 5, 2010
    690
    21
    I mean what are the voltage rating, current rating, wattage rating? Do you know?
    THANKS!!! :D
  4. debjit625
    Apr 17, 2010
    790
    186
    It should be written on the motor's body anywhere ,if not then its hard to tell by looking at the picture. The circuit where it was connected can also help to identify the motor's rating a bit. By looking at the picture ,it seems an induction kind of motor which works on AC.But I am not sure.
    Try to find more about the circuit it was connected to, it may go directly to mains but again not sure.
    Good luck
  5. BMorse
    Sep 26, 2009
    2,675
    234
    it is definitely an AC gear Motor, and from where you are at, most likely 220 VAC, low RPM's, and low torque..... not quite sure about the current draw..... seems to be rated for continuous operation since it has a built in fan, since those induction motors do get pretty hot, and most have a built in thermal switch wrapped up around the coil, I don't see one on this motor.
  6. shortbus
    Sep 30, 2009
    4,095
    1,681
