yes so before i use it i make voltage and temperature calibration and take my Precautions from errorsI agree completely with Bill's advice and would add that for real confidence in your measurements, it is important to add controls. The difference between calibration and controls can lead to a lengthy discussion, which is probably unnecessary here. Suffice it to say that calibration will often include testing several known objects to show and to adjust both linearity and accuracy. A control may be just one or two objects to show that the calibration has not changed.
Regards, John
The output is linear with weight (mass) on the load cell : I follows, y= mx+b in Algebra terms. You need to calibrate the zero point (b) so it reads zero at zero load. Then you need to calibrate the gain (m) so the output follows the desired voltage change per kilogram of mass change.yes so before i use it i make voltage and temperature calibration and take my Precautions from errors
