what is the problem with this schematic
Discussion in 'General Electronics Chat' started by spidermanIIII, Dec 26, 2013.
  1. spidermanIIII
    Nov 22, 2013
    76
    what is the problem with this schematic i need help please, in my college they asked for analog to digital converter using ADC0808 IC and potentiometer
    i built the schematic but it doesn't run in Proteus
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    What kind of buffers do you use?
    When they are open collector, there will never be any voltage on the leds.
    If they are not open collector types, you will need current limiting resistors for the leds.
    Bertus
  3. spidermanIIII
    Nov 22, 2013
    76
    i tried not to use buffers and it stil don't work
  4. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,387
    You have pin 22 ( the adress latching pin ) floating.
    You need a high input to store the selected adress.
    See the timing diagram what is needed to convert an input signal:
    Bertus
  5. paulktreg
    Distinguished Member
    Jun 2, 2008
    623
    124
    Have put resistors (try 1K) in series with the LEDs?
