What is the phenomenon
Discussion in 'General Science' started by RRITESH KAKKAR, Dec 1, 2015.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    I was searching you tube and found this experimental video. In this the lead of pencil glow why?
    is led glow when there is supply on it its legs or terminal?
  2. #12
    Nov 30, 2010
    16,665
    7,313
    A pencil core is almost the same thing as an old carbon resistor. Give it enough current and it will burn up...just like any other resistor.
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    OK, That mean the pencil lead is carbon resistor.
    then what is the resistance of it?
  4. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    In this video
    Experiments on refraction, reflection and total internal reflection
    at 00:15 sec The Coin Disappear due to total internal reflection, how i am confused.
  5. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I have done that at 5V 40Amps supply.
    the small front knob of pencil it does not happen.
  6. Techno Tronix
    Member
    Jan 10, 2015
    140
    10
    Great video.
    Graphite is a semi metal and it is an electrical conductor. It is non-inductive, and has a negative temperature coefficient.
  7. Glenn Holland
    Member
    Dec 26, 2014
    359
    114
    Graphite is inductive for the same reason that copper or a superconductor is inductive.
    If a substance can conduct at all, it will have inductance.
  8. #12
    Nov 30, 2010
    16,665
    7,313
    You have been on this site for over 5 years. That is enough time for you to have bought an ohm meter. Measure it yourself.
    shortbus likes this.
  9. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I have taken 1.25cm lead from pencil measuring resistance from Digital multi meter.
    it is showing non uniform Resistance 12 ohm 5 ohm like this.
    And It is burning as show in video now it taken some seconds to blow out.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    I suspect most fuses glow brightly before burning out.
  11. shortbus
    Sep 30, 2009
    4,088
    1,670
    He also should by now be able to Google his questions.
    He was recently banned a ETO for being a troll, for asking questions similar to his recent questions here. He had his name changed to koolguy over there.
    #12 likes this.
  12. #12
    Nov 30, 2010
    16,665
    7,313
    The glass fuses do, but those pesky cartridge fuses neither say nor show any sign when retiring from the business.:D
  13. #12
    Nov 30, 2010
    16,665
    7,313
    Profound ignorance goes with the job here. Failure to make any effort to help your self eventually becomes self defeating.
  14. KL7AJ
    Nov 4, 2008
    2,043
    292
    Pencil lead is graphite mixed with a ceramic powder...the harder the lead (lower number) the more ceramic.
  15. WBahn
    Mar 31, 2012
    18,085
    4,917
    There's more to it than this (as far as my understanding goes). In the H series, a higher number means a harder lead while in the B series a higher number means a softer lead. Most writing pencils are H series while drawing pencils are more likely to be B series.
  16. WBahn
    Mar 31, 2012
    18,085
    4,917
    The more interesting question is how are you not confused? (or at least that would be a much shorter list).
  17. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    how to overcome this?
  18. WBahn
    Mar 31, 2012
    18,085
    4,917
    Set your sights on something a bit less challenging?
  19. shortbus
    Sep 30, 2009
    4,088
    1,670
    No, KL7AJ has it correct. Although it is a form of clay added to the graphite, which you could I guess call it ceramic but they don't.
  20. WBahn
    Mar 31, 2012
    18,085
    4,917
    So you are saying that a 2H pencil is harder than a 9H pencil. Really?
