What is the name of this LED ?
Discussion in 'General Electronics Chat' started by Zanac-X, Jun 28, 2012.
  1. Zanac-X
    Dec 23, 2011
    51
    hey guys
    can anyone help me with any info about this type of LED like its name,data sheet,voltage... etc
    thanks very much
  2. Inquisitive
    Nov 12, 2011
    8
    9
    Looks like a standard mini Christmas light to me.
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
    Its an LED Christmas light bulb..
    The LEDs inside the housing vary from manufacturer to manufacturer..
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Are you sure it is a LED and not a light bulb
  5. BillB3857
    Feb 28, 2009
    2,402
    348
    Looks like a flasher Christmas tree light to me. May need to break it open to verify contents.
  6. mcgyvr
    Oct 15, 2009
    4,787
    973
    looking at the closer picture there doesn't seem to be an LED in there..Its just a regular bulb.
  7. Zanac-X
    Dec 23, 2011
    51
    ok....so its a bulb but i didnt get any info about it like its resistance, its max voltage or can i operate it on AC-DC
  8. t06afre
    May 11, 2009
    5,939
    1,222
    A conventional light bulb can operate on both DC and AC. For AC use the RMS value. Regarding the specs. I do not have any clue at all.
  9. ErnieM
    Apr 24, 2011
    7,435
    1,625
    It's a standard Christmas light, possibly a blinker due to the lower darker arm. The arm heats up when the bulb is lit, so it moves and beaks contact. Bulb goes off, cools, arm moves back, bulb lights, cycle repeats.
    An oft misunderstood part of these bulbs is the coil of wires around the two leads to the filament: these are there to short the bulb if the filament burns out. Note it is NOT a resistor, and if you compare the resistance of a burned out bulb to a working bulb the burned out one has a lower resistance!
    This is due to some interesting physics: these bulbs run in a series circuit of (typically) 35 or 50 bulbs. When a bulb burns out and opens it blocks the passage of current, so instead of seeing 1/35th or 1/50th of the line voltage it sees the full line voltage. This causes an arc to the thin insulation on this coil, which then arcs and welds itself across the now open filament, thus letting the other 34 or 49 bulbs remain lit.
    Obviously as more and more bulbs burn out the remainder run hotter and hotter. Eventually they will fail machine gun fashion but it does provide a more graceful degradation of functionality (and a chance for repair to the very observant).
    The best way to get the voltage this bulb runs at is to get the light string it came from and count the bulbs. Divide the line voltage b that number and you have it's operating voltage.
  10. MrChips
    Oct 2, 2009
    12,624
    3,451
    When one filament blows, the one lamp will only see 1/35 or 1/50 of the line voltage.
    Typically, such a Christmas tree lamp will run on 1.5 to 3V AC or DC.
    You can tell if it is a flasher or not by looking closely to see if there is a bi-metallic circuit breaker in the bulb.
    Ordinary Christmas tree bulb:
    Christmas tree flasher:
  11. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    The others are half-right. It is a standard incandescent christmas light bulb, not an LED. It is not a flasher, however. A flasher has a third "arm" that moves back and forth between the contacts, whereas yours only has two. This is basically what yours is:
    You can generally assume that a christmas light bulb runs on about 2.5 volts, but it varies widely.
  12. KJ6EAD
    Apr 30, 2011
    1,426
    363
    The last time I bought incandescent Christmas lights (a long time ago) they were all wired in series groups of 20 so the bulbs were all 6V.
    DerStrom8 likes this.
  13. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I've always had them wired in groups of 50, so 120v/50 bulbs = 2.4v/bulb.
