What is the name for a digital audio output DIP port?
Discussion in 'General Electronics Chat' started by Andrew Armstrong, Sep 8, 2016.
  1. Andrew Armstrong
    Sep 7, 2016
    24
    Hi! Can somebody please help me source a digital audio optical output port , if possible on the Farnell website : http://uk.farnell.com/
    I am looking for the Digital Optical Out port seen on the left of this picture :
    Something suitable for DIP would be great.
  2. R!f@@
    Apr 2, 2009
    8,793
    771
    What do you mean by "DIP" ?
  3. Kermit2
    Feb 5, 2010
    3,858
    968
    There is a conversion circuit needed to change laser light into electricity before you can mount a connector in a printed circuit board.
    Searching google show's some possible matches at alibaba
    I do not click on links to that site, but you are welcome to do so.
  4. Kermit2
    Feb 5, 2010
    3,858
    968
    Check page 9
  5. Kermit2
    Feb 5, 2010
    3,858
    968
    Pdf is saying it cannot be opened.
    Search for Toshiba TOSLINK adaptors and it will appear. You can get manf. Part numbers that will help you track down a seller.
  6. Kermit2
    Feb 5, 2010
    3,858
    968
    Trying to upload the pdf one more time
  7. Andrew Armstrong
    Sep 7, 2016
    24
    A chip that can slot into a breadboard rather than a SMB (surface mount board)
  8. Andrew Armstrong
    Sep 7, 2016
    24
    Searching for that really doesn't result in any useful outcomes. I really just need a source / supplier where I can purchase one of these Toshiba TOSLINK adaptors! Seems like i'm not the only one finding it hard to come by!
  9. crutschow
    Mar 14, 2008
    13,530
    3,393
    Do you need a chip or will a module such as this work for you.
  10. GopherT
    Nov 23, 2012
    6,340
    4,094
    Andrew Armstrong likes this.
  11. Andrew Armstrong
    Sep 7, 2016
    24
    Needs to be the chip!
  12. Andrew Armstrong
    Sep 7, 2016
    24
  13. GopherT
    Nov 23, 2012
    6,340
    4,094
  14. Andrew Armstrong
    Sep 7, 2016
    24
  15. GopherT
    Nov 23, 2012
    6,340
    4,094
    Magic
    Yes, the difference can be found by sending that question to the sales email address at the bottom of the datasheet.
  16. KeepItSimpleStupid
    Mar 4, 2014
    1,298
    225
    OJx - The x determines the mechanical layout or "footprint". Totally obvious
  17. Andrew Armstrong
    Sep 7, 2016
    24
    Seriously? is it that obvious? Not particularly obvious to me what the exact differences are!
  18. GopherT
    Nov 23, 2012
    6,340
    4,094
  19. KeepItSimpleStupid
    Mar 4, 2014
    1,298
    225
    OK
    -1 has TWO large plastic pins for PCB mounting, uses self-tapping screw
    -2 has THREE large plastic pins for PCB mounting, uses self-tapping screw
    -3 has TWO large plastic pins, no place for a screw
    See the PC Layout pattern for each.
    So basically they have a different PCB layout pattern and two of them mount with screws.
  20. kubeek
    Sep 20, 2005
    4,691
    806
    DIP means double in-line package (of ICs), just like all the old logic chips and whatnot. The word you are probably looking for is through hole, as oposed to smd.
