Hi.
I am not going to get into all the details again.
But i opened the thread again,since i couldn't figure out how was the 47KΩ compensating resistor calculate?
From the data sheet i found that the leakage current is about 12.8uA and when i calculate:12.8uA*47KΩ,the result is 0.6V.
This result made me assume that you had been devided the emitter-base voltage drop of the silicon transistor(0.6V)with the leakage current(12.8uA)and determine the 47KΩ.
But the compensating resistor is parallel,not only to the silicon E-B,but also to the led and the resistor,so the voltage drop on the compensating resistor is higher than 0.6V.(maybe 2.1V?).
So,how did you calculate the compensating resistor?which parameters did you use?
