What is the meaning of xky
Discussion in 'General Electronics Chat' started by rahdirs, Jun 21, 2013.
  1. rahdirs
    May 22, 2013
    28
    I have seen around in some elektor magazines that they write certain resistor values as 'x'kΩ'y'.What does 'y' mean ???
    Example:It was written that value of resistor R3 is 4kΩ7.What is that 7???
    Does he mean R3 = '7' 4kΩ resistors => 28 kΩ ????
  2. Dodgydave
    Jun 22, 2012
    5,155
    772
    4K7 means 4700 ohms or 4.7K ohms, K means 1000 ohms, M means 1000,000 ohms, and R means just ohms.
  3. GopherT
    Nov 23, 2012
    6,319
    4,043
    It would be 4k7Ω which is 4.7k Ω
  4. Ramussons
    May 3, 2013
    562
    92
    Yes. 4k7Ω means it is 4.7k Ohms.
    Ramesh
  5. rahdirs
    May 22, 2013
    28
    Yes,but at many places in the magazine he wrote it as xkΩy.So,it is the same as x.ykΩ.
    And at the end of mag. near component list he wrote for R3 as 9kΩ1 (9kΩ09).It should've meant 9.1kΩ,what is with that 9kΩ09 ????
  6. MrChips
    Oct 2, 2009
    12,636
    3,455
    Same thing.
    9.09kΩ
  7. studiot
    Nov 9, 2007
    5,005
    515
    The resulting confusion is why I would recommend sticking to the conventional representation as used by all the other responders.
    Just to expand.
    The letter (usually in terms of the multiplier prefix, kilo, mega etc) is placed instead of the decimal point
    So
    1.8 megohms becomes 1M8
    1.8 kilo ohms becomes 1k8
    and the symbol R is used for no prefix
    So
    1.8 ohms becomes 1R8
    This method is clear, simple and unambiguous.
    It is also much harder to loose the decimal point.
    Note that the international symbol for the ohm (or other unit), omega, should never appear in the middle of a value - that is just plain wrong.
    It should always be appended at the end
    eg 1.8Ω, 1k8Ω, 1M8Ω, 1.8 kΩ, 1.8MΩ and so on.
    Of course, the word or symbol ohms is generally redundant, you should consider whether you should be doing electronics if you don't know resistors are measures in ohms.
    rahdirs likes this.
