What is the main difference between Ground and Neutral?
Discussion in 'General Electronics Chat' started by Engr Mick, Apr 6, 2014.
  1. Engr Mick
    Jan 29, 2014
    11
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    If you are talking about the AC in your house, Neutral carries the return current from whatever you are operating. Ground is the safety wire to carry any current resulting from a fault in the device you are operating. Do a search. This has been discussed so many times with so many ways of explaining it.
  3. inwo
    Nov 7, 2013
    2,435
    315
    That's a good short explanation.
    I also like the "code" definition.
    Shorter yet.:D
    Neutral (wire)= grounded conductor.
    Ground (wire)= grounding conductor.
  4. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    In terms of the common AC supply they are considered to be at the same potential, one main distinction is that neutral is considered a current carrying conductor whereas the ground should never intentionally be used as as such.
    Max.
    ErnieM likes this.
  5. #12
    Nov 30, 2010
    16,663
    7,307
    Don't get too technical on this one. This is a school question. See Homework section for, "Which one is the best system... 60Hz or 50Hz."
  6. ErnieM
    Apr 24, 2011
    7,434
    1,625
    This one should have a sticky !!!
  7. BillB3857
    Feb 28, 2009
    2,402
    348
    When I was in the Navy, we had a drawing in our shop of an airplane towing a bucket of dirt for a ground.
  8. profbuxton
    Member
    Feb 21, 2014
    233
    68
    Well, thats all very well for the aircraft ground, But where do you connect to ground on a Navy ship.
    Pot plant, perhaps?
  9. BillB3857
    Feb 28, 2009
    2,402
    348
    That's what the anchor does. Problem is that it slows the ship down a lot.:)
  10. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Or the expression 'Swinging the Lead' takes on another connotation.:p
    Max.
  11. BillB3857
    Feb 28, 2009
    2,402
    348
    Talking about swinging the lead...... I forgot to retract the trailing wire antenna (150' of copper clad steel wire with a 5 lb lead weight) only once. What a mess of wire on the runway when we landed. No telling how many gooney birds I wiped out.
  12. atferrari
    Jan 6, 2004
    2,663
    783
    For the antennas, the best ground plane, is the water. :p :D
