What is the IC inside the 160-in-one Electronics Project Kit?
Discussion in 'General Electronics Chat' started by electrik890, Feb 2, 2013.
  1. electrik890
    Jul 22, 2012
    6
    The manual wasn't any help. It simply said Integrated Circuit BA-306. A search on this didn't come up with anything relevant.
  2. electrik890
    Jul 22, 2012
    6
    And if perhaps it's impossible to order this IC, I'd like to replicate the IC schematic. What NPN transistors do you suggest I use?
  3. WBahn
    Mar 31, 2012
    18,088
    4,917
    What more did you expect from the manual beyond the part number?
    What are you looking for that didn't come up in your search on it?
    When I put it in Google I almost immediately found that it was a SIP07 packaged audio amplifier made by RoHM and that there are some available on EBay in the UK.
  4. electrik890
    Jul 22, 2012
    6
    @WBahn,
    I no longer have the kit but I still have the manual. As far as what I expected from the product manual? How about an IC model number... the 200-in-one electronic project kit manual provides that for its ICs. I'd love to know what search term you used.
  5. WBahn
    Mar 31, 2012
    18,088
    4,917
    The BA-306 is the IC model number, just like 74HC7400 or LM555 would be.
    Does the IC (based on what you remember or what you can see in pictures or in the manual) have seven pins all on the same side?
  6. electrik890
    Jul 22, 2012
    6
    Good question. I don't know.
  7. tracecom
    Apr 16, 2010
    3,879
    1,396
    That looks like it in the picture, just under the speaker.
    ETA: I didn't see the closeup you already posted until now, so I guess you knew where it was.
  8. WBahn
    Mar 31, 2012
    18,088
    4,917
    Yeah, that looks like a SIP, but you can't see how many pins.
    The schematic on the board only shows six connections. I was hoping to find a datasheet or something that would give the pinout, but wasn't that lucky. Perhaps there is an unconnected pin or perhaps there is just a pin that is unused in this circuit.
    My supposition is that this part is so out of date that it will be hard to find much informaiton on it, although I did find actual parts for sale on E-Bay. My first guess is that any modern small signal transistor will work as a suitable replacement. I don't think there is anything in that circuit that requires close matching.
  9. Zpag Pag
    Jun 8, 2016
    6
  10. Zpag Pag
    Jun 8, 2016
    6
  11. KJ6EAD
    Apr 30, 2011
    1,426
    364
  12. hp1729
    Nov 23, 2015
    2,105
    235
    You want to duplicate the circuit on another board? Start with 2N3904 or 2N4401 transistors. Or what ever you have on hand.
  13. atferrari
    Jan 6, 2004
    2,669
    784
    Maybe he abandoned the project some time ago.
    GopherT likes this.
  14. KJ6EAD
    Apr 30, 2011
    1,426
    364
    Probably so but these X-in-1 kits are ubiquitous and long-lived, being handed down multigenerationally, so updating the thread with current restoration resources will help someone eventually.
  15. Zpag Pag
    Jun 8, 2016
    6
    I bought 5 BA306 on Ebay ...
  16. hp1729
    Nov 23, 2015
    2,105
    235
    Please keep us up on how that works out for you.
