Pin five accesses an internal node that is obtained from the supply/ground pins via a voltage divider. This node establishes the reference voltages for the comparators. Adding a capacitor stabilized the voltage by suppressing the high frequency noise. But you can also overdrive the pin and establish your own voltage level on that node and thereby control the thresholds more directly (which is why it is usually labeled the 'control' pin).
