For my project, i need ztx313. But in my country, i didn't find it. As i am studying in mechanical engineering,i have a little knowledge in electric field. Can anyone inform me what are the equivalent transistor of ztx313?
ztx313
it depends on what kind of equivalency you are looking for: similar breakdown voltage? beta? packaging? number of pins? ...what are the equivalent transistor of ztx313?
wouldn't that depend on your circuit?actually i have to keep constant current flow for my project. so what is the equivalent resistor of ztx313?
it's my hot wire anemometer circuit diagram. only transistor ztx313 could not be found, what are the alternatives of it?wouldn't that depend on your circuit?
it depends on the (max) value of R11(2).it's my hot wire anemometer circuit diagram. only transistor ztx313 could not be found, what are the alternatives of it?
hey may i have your mail address? I need to know something about this project. If you can, it will be so much appreciated. literally i am facing lots of troubles.it depends on the (max) value of R11(2).
but the circuit doesn't seem to utilize any special properties of the ztx313. so any small signal transistor, like 2222, 5551, etc., would work. I don't think darlington is required either.
the 358 would be a much better substitute for the 741 here, especially since you are already using one.
BSV26? 2N4400, pin out is good of you face it the right way.For my project, i need ztx313. But in my country, i didn't find it. As i am studying in mechanical engineering,i have a little knowledge in electric field. Can anyone inform me what are the equivalent transistor of ztx313?
by Jake Hertz
by Duane Benson
by Jake Hertz
by Duane Benson
