What is the difference between indexer control, and Serial control?
Discussion in 'General Electronics Chat' started by FlightSim12, Jun 21, 2016.
  1. FlightSim12
    Jun 21, 2016
    I am trying to choose a stepper motor controller for a 2 phase unipolar stepper, and I don't want PWM because I have limited PWM outputs on the microcontroller I am using. So I looked around and found stepper motor drivers that are controlled by an indexer and Serial(such as SPI). But I cannot find a satisfactory explanation of indexer control, so I would like to know whether or not the indexer step/dir control pins just work off of plain binary, like a 0 for clockwise and a 1 for counter clockwise, and a 0 for no movement and a 1 for "move one step"? I would also like to know the pros and cons of each control type.
  2. Sensacell
    Jun 19, 2012
    1,183
    276
    Note that an "indexer" and "driver" are two different beasts entirely.
    A stepper "driver" accepts step and direction inputs- this makes you in charge of handling the (non-trivial) pulse counting and timing tasks required.
    An "indexer" is a device that creates the step and direction signals itself from macro 'move' commands you send it, handling all the messy stuff internally. An indexer typically needs a driver, although some combine both.
  3. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,514
    A simple indexer uses a pulse chain the rate of which controls the rpm, a separate 1 - or 0 input decides the direction.
    Most drives use this method, the PWM is used for the actual coil switching, the old series resistor method can also be used for non-switched outputs.
    Max.
  4. FlightSim12
    Jun 21, 2016
    So that would be the easiest method for controlling multiple steppers with a microcontroller connected to a Stepper motor driver IC that uses the indexer like this chip from TI? http://www.ti.com/product/DRV8805/datasheet
  5. MaxHeadRoom
    Jul 18, 2013
    10,839
    2,514
    If using pic micro check out the Mechatronics application board link the software is in the link also.
    Max.
