What is the differece between " OC (Open Collector Gate) " and "inverter" ??????
Discussion in 'General Electronics Chat' started by goodggg, Jun 15, 2013.
  1. goodggg
    Feb 6, 2013
    :)What is the differece between " OC (Open Collector Gate) " and
    " inverter " ??????
    Are they the same??????
    I am sorry to disturb to you, and also sorry to ask such a simple question!!!!!!
  2. Dodgydave
    Jun 22, 2012
    5,159
    772
    In an inverter the input signal is reversed ( so input posative , outputs negative) with an open collector you have to provide a Load resistor to pull the collector to posative supply.
    collector
    inverter
  3. Jony130
    Feb 17, 2009
    3,993
    1,116
    No Open Collector in not a gate. It is a typo of a output that gates can have.
    In general we have a two types of a outputs.
    The complementary (totem pole) outputs. And open collector output.
    http://en.wikipedia.org/wiki/Open_collector
