What is the dc component in this case?
Discussion in 'General Electronics Chat' started by Bonjo Amy Sefala, Jun 18, 2015.
  1. Bonjo Amy Sefala
    Jun 18, 2015
    May I ask....what is the dc component in this case?
  2. Lestraveled
    May 19, 2014
    1,957
    1,218
    If it is a pure sine wave and is symmetric around zero volts, then the DC component would be zero.
  3. mxg2579
    Jun 10, 2015
    15
    7
    Since the question states that it has a vertical offset of 1.5V, that would be the DC component. Unless I am confusing that with something else.
  4. ErnieM
    Apr 24, 2011
    7,439
    1,627
    How does the offset work in that scope? On mine, a 1.5V offfset moves the trace UP.
    Assuming zero volts is mid screen we had to add 1.5 to the wave to move it up and center it, so the wave has a negative 1.5V offset.
    And welcome to the forums! (I wanted to say "circus" as I expect everyone who wanders thru this post today to have a different answer.)
    Bonjo Amy Sefala and #12 like this.
  5. #12
    Nov 30, 2010
    16,704
    7,352
    I'm with Ernie. The problem did not say the scope had a negative 1.5V vertical offset, so it must be that the scope has a positive 1.5V offset dialed in with its adjustments.
  6. Bonjo Amy Sefala
    Jun 18, 2015
    So that the dc component is -1.5V?
  7. KLillie
    Member
    May 31, 2014
    126
    14
    Yes
