The attached diagram is for an op-amp circuit for a seismograph that records earthquakes at Griffith Observatory in Los Angeles.
The ground motion sensor is shown in the first image and it has a magnetic variable reluctance transducer where a mass is suspended from a spring and the displacement between the mass and the frame varies the air gap between a magnet and two iron cores with multiple output coils.
The output of the transducer is amplified to drive the pen galvanometers on a rotating drum recorder like the one shown in my avatar.
The diagram shows a four stage amplifier composed of four 741 op-amps with a "compressor amp".
However, what does the compressor amp do?
