what is the C and T on a battery?
Discussion in 'General Electronics Chat' started by dingo, Mar 19, 2011.
  1. dingo
    Mar 11, 2011
    34
  2. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    likely has to do with a thermistor that is placed within the cells for a high quality charger.
  3. dingo
    Mar 11, 2011
    34
    Oh. So do you have any idea on that "C"? My device seems to give me error messages everytime I block this connector.
  4. Jaguarjoe
    Apr 7, 2010
    770
    90
    Is their a "C"enter tap on the batteries?
  5. mcgyvr
    Oct 15, 2009
    4,791
    976
    T=temperature
    C=serial communication terminal
  6. dingo
    Mar 11, 2011
    34
    thanks mcgyvr. I tried searching for more information online but there are none.
    Do you know how they are connected? and how they are used?
  7. PackratKing
    Jul 13, 2008
    850
    216
    T, is likely a circuit inside, and used by the device to sample the temperature of the charging battery, to stop the charge and provide some kind of alarm if things get too hot.
    C , is likely the circuit in the device judging the accrued voltage charged to the battery, so it can stop the charging when complete.
    + & - is charger polarity.
  8. dingo
    Mar 11, 2011
    34
    Hi there PackratKing,
    That is some sweet info. The problem I have with my camera right now is that if I block the battery's C then the camera still turns on, but then gives me an error saying that i must use a correct type of battery. After 5 seconds it turns off. Do you know how the C is connecting from the inside of the battery? I don't need any type of charging so I would like to experiment.
  9. PackratKing
    Jul 13, 2008
    850
    216
    "" Do you know how the C is connecting from the inside of the battery? ""
    Nope.....never "autopsied" one of those. :D
  10. dingo
    Mar 11, 2011
    34
    hehehe. Yes I'm thinking about doing it today :)
  11. mcgyvr
    Oct 15, 2009
    4,791
    976
    Why are you blocking the C terminal?
    Your camera is expecting the communications signal on that terminal to give battery information. Probably 1-wire serial data
  12. dingo
    Mar 11, 2011
    34
    I'm blocking the C terminal because I wanted to see what happens and what it is used for.
    Okay so i've open up the battery and there is a little circuit inside it take takes in a NEG and POS into the circuit. The Circuit then have Four Connectors OUT: +, T, -, C. I will post up the Circuit soon.
