what is the application of capacitor with 0.01 in this led chaser
Discussion in 'General Electronics Chat' started by placide, Sep 13, 2012.
  1. placide
    Oct 1, 2011
    22
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    There seem to be two images in your post, but they are blocked.
    Can you UPLOAD the images to this forum.
    Attachments and Images
    Bertus
  3. placide
    Oct 1, 2011
    22
    you can now check the link.
  4. placide
    Oct 1, 2011
    22
  5. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    The capacitor on pin 5 of the NE555 is there to have noise on the reference reduced.
    There is a voltage divider inside the NE555 and pin 5 is made available outside.
    The 1K resistor in the cathodes of the LEDS is to regulate the current through the leds.
    Bertus
  6. placide
    Oct 1, 2011
    22
    the capacitor i meant is not that one on pin 5
  7. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The other 0.01uF cap that is connected to pin 8 of the 555 should actually be two separate caps; one 0.1uF ceramic or metal poly film, and one 1uF or greater aluminum electrolytic. Have a look at National Semiconductor's datasheet on the LM555 timer; you'll find that recommendation within it.
    The CD4017B should have its' own 0.1uF bypass cap connected across its' Vdd/Vss pins.
  9. placide
    Oct 1, 2011
    22
    decoupling wow, what does it decouples
  10. MrChips
    Oct 2, 2009
    12,622
    3,451
  11. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    @MrChips:
    Did you see the link I posted in post #7?
    Bertus
  12. MrChips
    Oct 2, 2009
    12,622
    3,451
    Sorry Bertus, no, I have been busy all day and did not check your post.
