what is that diode used for
Discussion in 'General Electronics Chat' started by luciforlove, Oct 19, 2012.
  1. luciforlove
    Sep 11, 2012
    hi,all!
    the diode(D1) between the second BJT'b and e,what it use for,it does influence dc and signal amplification during simulation.
    thank you
  2. R!f@@
    Apr 2, 2009
    8,792
    771
    U know u should really learn to tell more abt ur circuit before asking questions.
    Secondly here we have Grand Pa's :D mostly. So I think u should put a clear screen shot. Even I can't make out beside the symbols.
  3. crutschow
    Mar 14, 2008
    13,509
    3,385
    That's a real Rube Goldberg of a circuit. :rolleyes: If you tell us what it is supposed to do (and what those squares represent) we might be able to help.
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    I am afraid I have to agree, the schematic is missing too much information to be of much use. I move it to local after waiting almost a minute to upload (I have fiber optic). Did you draw this yourself, or where did you get it?
  5. PackratKing
    Jul 13, 2008
    850
    216
  6. Audioguru
    Dec 20, 2007
    9,411
    896
    The schematic is fuzzy because it was saved and posted as a fuzzy JPG file type instead of as a very clear PNG file type.
    Its parts are spread out too much which makes them small.
    Also the schematic is covered with chicken pox dots and tiny text all over it.
    The grey background should be white.
  7. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Usually, this diode protects the base-emitter junction from reverse breakdown. If you don't know why the components are on the schematic you shouldn't be on a simulator; that is like letting a chimp drive your car.
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    Diodes can be used for several purposes:
    You can use them to rectify signals.
    You can use them to isolate signals.
    You can use them to switch signals.
    You can use them to attenuate signals.
    In the circuit given it is not clear how the diodes are used.
    Bertus
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    Hee, hee.
    A chimp does drive my car. ME!
  10. BillB3857
    Feb 28, 2009
    2,402
    348
    Possibly to prevent more than .7V Negative voltage from going into the 2nd box, (whatever that is)
  11. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    It is really too much demanded trying to understand what this schematic is about. It is too small, nothing can be read properly. And what is it actually? Confused.
    Diodes are used from many things: dropping voltage, creating a bias, lock out reverse voltage, rectifying...or in a radio perhaps if you fancy.
  12. Ron H
    Apr 14, 2005
    7,050
    657
    If those little squares represent BJTs (which you implied), why do they have 4 terminals?
  13. R!f@@
    Apr 2, 2009
    8,792
    771
  14. ErnieM
    Apr 24, 2011
    7,442
    1,628
    Cool list, what else can we add?
    You can use them to clamp signals.
    You can use them as a constant current source.
    You can use them as a variable capacitor.
    This is fun!
  15. MrChips
    Oct 2, 2009
    12,648
    3,458
    You can use them to log signals.
    You can use them to fuzz signals.
    You can use them to or signals.
  16. kubeek
    Sep 20, 2005
    4,691
    806
    RF transitors as I recall have four terminals because of reasons unknown to me, and the values look like this operates at some high frequency, so my gues is some HF amplifier.
    Also I hazard to guess that the left pin is base, bottom and top are emmiter(s) and right pin is collector.
