What is Temperature Hysteresis?
Discussion in 'General Electronics Chat' started by bugserm, Oct 28, 2011.
  1. bugserm
    Oct 28, 2011
    Hallo everyone..
    i was reading ADT7310 temperature sensor datasheet & bumped into this term "temperature hysteresis". Does anybony know what that means. thnx alots :)
  2. BillB3857
    Feb 28, 2009
    2,402
    348
    Normally, Hysteresis represents an amount of change of one variable needed to cause a change in another. In this case, the hysteresis is documented as 0.02 degrees C. A typical home heating/cooling thermostat has a built in hysteresis of a couple of degrees to prevent the heating/cooling system from short cycling.
    On edit; Analog signals are constantly variable, and if operating an ON/OFF device, or being converted to digital, a certain amount of hysteresis will be present. If an 8 bit A/D converter has a range of 0 to 10v, each bit change in the count would represent a change of 10/255 volt. Any change less than that would be considered hysteresis. At least that is the way I understand it. Others may have differnt thoughts.
    bugserm likes this.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Adding on to what was said, a typical freon air conditioner will be damaged it turned off then turned on too quickly. It isn't good for the heater either. By allowing a typical 2° window this is eliminated.
    bugserm likes this.
