what is so special about TWO PORT NETWORKS?
Discussion in 'General Electronics Chat' started by matrixofdynamism, Feb 20, 2012.
  1. matrixofdynamism
    Feb 8, 2009
    11
    Why is there so much talk about two port networks in books and stuff I don't fully understand, what happens if a thing is not two port?
  2. Brownout
    Jan 10, 2012
    2,375
    998
    Because that's how devices are characterized. If you're a student, this will be one of the most importand concepts you'll learn.
  3. Vahe
    Member
    Mar 3, 2011
    75
    9
    two ports are important in the characterization of networks and can be used as the basis of studying feedback in amplifiers.
  4. crutschow
    Mar 14, 2008
    13,466
    3,356
    A two-port network allows an output that is different from the input. It's typical of most amplifiers and makes the network relatively easy to analyze.
    Some networks can have only one port, such as the old tunnel diode high frequency amplifiers, which made them generally difficult to analyze and design.
  5. Glenn Holland
    Member
    Dec 26, 2014
    359
    114
    When I first heard of a "Two Port Network", I thought it was about the streets and highways through the Port Of Los Angeles and the Port of Long Beach, both located next to each other in Southern California.
    Shucks, I should have posted this in the Jokes department!!! :p
  6. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,836
    1,308
    Abstractly speaking; physical phenomena are often conveniently regarded as scalar in nature -- hence the tendency to 'reduce' systems to 'binary' paradigms for analytical purposes -- I know!:rolleyes: -- But what can I say? As time and tradition attest, it is an effective approach:D
    Best regards
    HP
