Not always true, Wikipedia is not a reliable source.Wikipedia, where you got the diagram, says so, so it must be true.
Are you sure? Your wife told me about your honeymoon.I have never seen anything that has a 0 length or a 0 time.
but i seen in RF designs. the designs isbuild based on S parametter. for exampleHello,
Ha ha.
Is this really a valid question? A zero length transmission line isnt a transmission line anymore. A transmission line has characteristics based on its makeup and if there is no length then there is no parameters for the transmission line itself. A direct short has 0 impedance. Since the length is zero, how do we distinguish the transmitted signal from the reflected signal.
One of the parameters of a transmission line equation is the length, and if the length is zero then there must be no delay from one end to the other, in either direction.
Just some quick thoughts.
Where did this question originate?
The existence of a transmission line depends on the frequency of operation. In the millimeter wave region of the RF spectrum -- everything, including component leads and PCB traces, is a transmission line. At lower frequencies -- not so much. Impedance matching in circuits is maybe not as important as you might think for a variety of reasons.but i seen in RF designs. the designs isbuild based on S parametter. for example
design based Sparameter with no transmition line,Why?
if the line is available, what is it being in the schematic
please help me
OK Thank you so much.The existence of a transmission line depends on the frequency of operation. In the millimeter wave region of the RF spectrum -- everything, including component leads and PCB traces, is a transmission line. At lower frequencies -- not so much. Impedance matching in circuits is maybe not as important as you might think for a variety of reasons.
by Aaron Carman
by Jake Hertz
by Duane Benson
by Jake Hertz
