What is meant by instruction cycle and clock cycle ?
Discussion in 'Embedded Systems and Microcontrollers' started by abhimanyu143, Jan 28, 2015.
  1. abhimanyu143
    Aug 25, 2014
    211
    hello ,
    I need some help , I am confused on some terms.
    1. The instruction time ?
    2. instruction cycle ?
    3. clock cycle ?
    instruction cycle
    fetch-and-execute cycle, fetch-decode-execute cycle
    8051 runs on 12MHz
    How is the 'clock cycle' of 8051 MCU related to the 'crystal' oscillator ?
  2. sevenfold4
    Member
    Jan 12, 2015
    80
    7
    The clock cycle is the period of the clock that you're feeding the to the micro (e.g. , a clock cycle takes 1us if the oscillator's frequency is 1MHz). The instruction cycle depends on the internal structure of the microcontroller or processor you use. E.g. , for a PIC an instruction cycle takes 4 clock cycles, for an 8051 it takes 12 cycles. This is because an instruction has multiple stages, like fetch, decode, execute and writeback.
    http://www.8051projects.net/plugins/forum/forum_viewtopic.php?41545.0#post_41554
    This page shows how Timer values are calculated, maybe it will serve you as an example.
    abhimanyu143 likes this.
  3. abhimanyu143
    Aug 25, 2014
    211
    I am explaining with your example.
    Example: a clock cycle takes 1us if the oscillator's frequency is 1MHz
    explanations: 1 us for fetch cycle and 1 us for execute cycle. that means it take 2 us
    explanations: it take 3 us.
  4. sevenfold4
    Member
    Jan 12, 2015
    80
    7
    Your wording is weird
    Anyways
    1 Clock period = 1/frequency of the oscillator
    1 Machine cycle = 12 oscillator periods (In case of 8051, because of the inner structure)
    1 Instruction cycle = 1-4 machine cycles (Depending on the instruction given for 8051)
    So if 1 machine cycle would calculate to 1us, then 1 instruction would take 1us (Depending on the instruction)
    I think... In the past i just did the calculations and never really had to go too deep into it.
    Correct me if i am wrong
  5. abhimanyu143
    Aug 25, 2014
    211
    actually I don't understand what do you mean, still I am confused on following terms.
    3. clock cycle ?
  6. sevenfold4
    Member
    Jan 12, 2015
    80
    7
    1. I guess that would be the time it takes to run 1 cycle?
    2. Is the time to run the instructions.
    3. Is the speed of the clock depending of the crystal and structure of your mcu
  7. vikasbly44
    Jan 19, 2015
    13
    The instruction cycle is the time period during which one instruction is fetched from memory and executed when a computer is given an instruction to machine language.
    The clock cycle is the time between two adjacent pulses of the oscillator that sets the tempo of the computer processor.
