What is "holding current"? (Resettable fuse / polyfuse)
Discussion in 'General Electronics Chat' started by daviddeakin, Mar 27, 2014.
  1. daviddeakin
    Thread Starter Active Member
    Aug 6, 2009
    207
    27
    With regard to polyfuses, can someone explain to me the significance of the 'holding current'? The trip current seems straightforward- the current beyond which the resistance increases suddenly, but what is the holding current rating for?
  2. R!f@@
    Apr 2, 2009
    8,793
    771
    Could it be the maximum continues current ?
  3. t06afre
    May 11, 2009
    5,939
    1,222
    As I understand it the hold current is the current in which the fuse will be closed(not tripped). Polyswitchs are thermally activated. So any change in the temperature around the device will influence the performance of the polyswitch. As the temperature around the polyswitch increases, less energy is required to trip the device and thus the hold current decreases. Around room temperature the hold current is about 100% At -40 degree celsius the hold current is about 10% larger. But at 80 degree celsius you will find the hold current may be 50% lower than room temperature
  4. daviddeakin
    Aug 6, 2009
    207
    27
    So do you mean that the holding current is a bit like a "minimum trip current" under maximum temperature conditions? In other words, under the hottest conditions, the trip point won't drop below the holding current rating?
  5. sirch2
    Jan 21, 2013
    1,008
    351
  6. t06afre
    May 11, 2009
    5,939
    1,222
    As the temperature around the polyswitch increase both tripping and hold current will decrease. Both hold and trip-current characteristics of polyswitch devices are a function of temperature.
