Either the coils are rotating (armature rotating) and the magnets are stationary (then you need brushes to make contact to the coils rotating on the shaft), or, you have the coils stationary (not called an armature since they are not rotating) and the magnets rotating - this is called a brushless DC motor since no brushes are needed to provide power to the spinning shaft.what is difference between armature and no armature in Dc motor ?
what will happen in the circuit if there is armature and no armature in dc motor?
@TimeZero --- Think 'motorized bicycle generator' -or- continuously sequenced stepper motor (as implemented, for instance, in electronics cooling fans, etc...) -- That said - I doubt DC operation is possible sans commutation -- Note that 'external' commutation schemes (e.g. stepper drivers) do not supply DC to the field windings (as seen over the entire 360° of rotation)or, you have the coils stationary (not called an armature since they are not rotating) and the magnets rotating - this is called a brushless DC motor since no brushes are needed to provide power to the spinning shaft.
Assuming the PS parameters and mechanical load are within operational limits, the rotor/armature will turn (IOW: the motors will 'run')...what will happen in the circuit if there is armature and no armature in dc motor?
Too true! Cuz pm rotor and pure DC energized stator without polarity switching is same as pm rotor and pm stator! If that runs you're having free lunch complements to chefs Keely and MayerThat said - I doubt DC operation is possible sans commutation
I say electromagnet alone not motor but if it move something like if solenoid or voice coil then _linear_ motorA motor(usually DC) with no armature is a electromagnet. It does nothing but generate an electromagnetic field in the poles
Without wishing to appear a 'budinski' -- IMHO solenoids (including true voice coils), linear (as opposed to pivoted) relay actuation mechanisms, 'rail guns', etc... are indeed linear motors -- whereas so called 'voice coil' head positioners, pivoted relay actuators, promotional 'wig-wags' and their ilk represent limited angular motors... Of course it goes without saying that, as a practical matter, 'linear motors' are, in fact, 'rectilinear motors' owing to the necessarily discontinuous nature of their operation...But I do not consider these to be "linear motors".
Indeed - such would seem a matter of semantics - It seems 'armature' is variably defined as follows:I have never heard of voice coil being called an "armature', not quite sure what a solenoid core is called, "plunger"
No arguments there!And the question was about DC motors in particular.
Remove the armature from a dc motor and it is no longer a "motor".
Speaking for myself, said digression owed merely to the facts that the OP was ambiguous taken with the observation that so called 'DC' brushless motors are, in fact, continuously sequenced stepper motors and hence not truly 'DC' operated at the 'motor level', if you will -- To see this you need only dissect such a device (e.g. a PC PSU cooling fan) to note the embedded 'stepping' (i.e. commutation) electronics...I am not sure how the responses got off track talking about "stepper motors" and "brushless motors"
I apologize that my post must have appeared confrontational and/or condescending? - Such was not my intent! Moreover, my 'expertise' where electromechanical devices are concerned is rather limited -- Anyway, it seems our disagreement{s} are those of nomenclature as opposed to 'substance'?No doubt your experience and expertise is vastly greater than my paltry 56 years working in many fields of the electrical industry
I say commutation in DC motor means switching current and polarity on windings of armature or sometimes stator by mechanical means like with brushes or electronically like with brushless DC motor. So being too technical there is no such thing as purely DC motor But for practicality I say brush commutated motor is real DC motor but brushless DC motor is only called DC because operation transparent to user Plz don't let my opinions anger anyone! I'm just upstart vicenarian lucky to know how to tie my shoes! OBTW I say slip rings not commutator cuz they are not switch!As far as PC fans go, even though supplied with DC they incorporate electronics to drive coils in the "stator" al la stepping motors. In my view, I would not call this "commutation". Same applies to "brushless dc motors".
It is surely a question of semantics - and the location (onboard vs off-board) of the driving electrons. For example, A two-wire PC fan may appear to be DC when examined by most casual observers whereas a three-wire BLDC motor used by model airplane enthusiasts will surely raise eyebrows when trying proper assign polarity to the 3 connections. Especially when common nomenclature deems these motors to be "brushless DC".Speaking for myself, said digression owed merely to the facts that the OP was ambiguous taken with the observation that so called 'DC' brushless motors are, in fact, continuously sequenced stepper motors and hence not truly 'DC' operated at the 'motor level', if you will -- To see this you need only dissect such a device (e.g. a PC PSU cooling fan) to note the embedded 'stepping' (i.e. commutation) electronics...
In all seriousness, if you are privy to a means of continuous, pure DC operation of an electromagnetic motor (of any topology) sans commutation please share! -- Though, as per @Aleph(0), it would seem the implications of such a possibility would necessarily extend to 'over unity'/truly 'free energy'
Again, sincere apologies should my officiousness have offended!
Respectfully
HP
Indeed! But the big question is -- can you manage a bow-knot sans reference to your smart phone? --- Hey! No offense intended! There are plenty of numpties in my generation tooI'm just upstart vicenarian lucky to know how to tie my shoes
Exactly! --- "Haven't you heard it's a battle of words the poster bearer cried..." (Attribution: Waters? Gilmore? Whoever)It is surely a question of semantics
by Aaron Carman
by Aaron Carman
by Jeff Child
by Aaron Carman
