What is bulb
Discussion in 'General Electronics Chat' started by Vindhyachal Takniki, Mar 6, 2016.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    1. In attached pic what is this bulb. In circuit it is directly connected to 220Vac manis via a 470k resistor as you can see pic.
    It has two filaments is it as you can see. What ac is applied it both glows. But when ac is given by clipping negative half by a diode, only one filament glows.
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
  3. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    Neon if fed from AC both electrodes glow, if DC then only one glows.
    Max.
  4. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
  5. Dodgydave
    Jun 22, 2012
    5,134
    767
    Its a neon bulb, they have a strike voltage of approx 70V, they make ideal mains indicators with a series resistor.
  6. MaxHeadRoom
    Jul 18, 2013
    10,827
    2,495
    A Neon is also used in the tester type mains screwdrivers that use body conductance to earth to indicate a live circuit, the pocket clip has to be held in order to complete the circuit for the neon to light.
    Max.,
    Vindhyachal Takniki likes this.
